rafiki
<o:smarttagtype namespaceuri="urn:schemas-microsoft-com:office:smarttags" name="metricconverter"></o:smarttagtype><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:HyphenationZone>21</w:HyphenationZone> <wunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--><o></o> Pues si, las CRI son intensas e incluso crueles ya que nos empujan a vender piezas que pensabamos que eran « intransferibles » y que no imaginabamos dejar partir NUNCA <!--[if gte vml 1]><v:shapetype id="_x0000_t75" coordsize="21600,21600" o:spt="75" oreferrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f" stroked="f"> <v:stroke joinstyle="miter"/> <v:formulas> <v:f eqn="if lineDrawn pixelLineWidth 0"/> <v:f eqn="sum @0 1 0"/> <v:f eqn="sum 0 0 @1"/> <v:f eqn="prod @2 1 2"/> <v:f eqn="prod @3 21600 pixelWidth"/> <v:f eqn="prod @3 21600 pixelHeight"/> <v:f eqn="sum @0 0 1"/> <v:f eqn="prod @6 1 2"/> <v:f eqn="prod @7 21600 pixelWidth"/> <v:f eqn="sum @8 21600 0"/> <v:f eqn="prod @7 21600 pixelHeight"/> <v:f eqn="sum @10 21600 0"/> </v:formulas> <vath o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"/> <o:lock v:ext="edit" aspectratio="t"/> </v:shapetype><v:shape id="_x0000_i1025" type="#_x0000_t75" alt="" style='width:12.75pt; height:12pt'> <v:imagedata src="file:///C:\Users\Rafael\AppData\Local\Temp\msohtml1\01\clip_image001.gif" o:href="http://forumamontres.forumactif.com/users/25/03/71/smiles/gros_yeu.gif"/> </v:shape><![endif]--><!--[if !vml]-->
Vendo mi estupendo Omega Seamaster 300 de 1968, completamente restaurado hace 1 año!<o></o>
Es poco habitual encontrar una pieza en semejante estado de conservación y sobre todo con la pátina que éste tiene… además, el tritio del bisel sigue siendo luminiscente!!<o></o>
En su dia escribí una revista comparativa entre este Vintage y un reciente Watchco:<o></o>
https://relojes-especiales.com/thre...r-300-de-1967-vs-seamaster-300-watchco.76417/<o></o>
<o> </o>
Cristal mineral con logo Omega, espesor <st1:metricconverter productid="14 mm" w:st="on">14 mm</st1:metricconverter>.<o></o> 41 mm de diámetro, 44 con corona.<style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--><st1:metricconverter productid="41 mm" w:st="on"></st1:metricconverter>
Equipa en legendario y fiabilisimo calibre 565, con fecha cuya caracterisca es el cambio de fecha tirando sobre la corona en vez de girarla.
Reloj vendido con una correa ABP en cocodrilo negra y cierre « deployante » Omega.<o></o>
Añado el armis Omega de acero original del reloj.<o></o>
<o> </o>
<o> </o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o>
</o>
Gracias por leer.<o></o>
Envio por MRW o equivalente.<o></o>
Precio 2950 €<o></o>
Para toda pregunta privado o email a rafiki3107 « aroba »gmail.com<o></o>
<o> </o>
<o> </o>
<o> </o>
- Algunas fotos:
<o>
</o>
